Old 01-05-2014, 12:08 PM
gophred's Avatar
gophred gophred is offline
Default Cub Cadet 129 steering upgrade
I figured I would post a fresh listing of the parts for this upgrade. I can't find where I originally found these numbers. This is for putting a thrust needle roller bearing on the steering pivot (at the box) to reduce friction. Some folks use a regular bearing, not sure on those numbers but it should be easy to find a 5/8" bearing that will work.
mcmaster carr numbers
5909K32 - cage assy for 5/8" shaft diameter, 1-1/8"OD thrust needle -roller bearing ($3.02)
5909K45 - .032" thick washer for 5/8" shaft diameter, 1-1/8"OD thrust needle -roller bearing (need 2 0f these - $1.07ea)
94945A230 - grade 8 steel nylon-insert 5/8"X18 thread ($8.09 pack of 5)
5 minute job if you have the tools out, belly pan off and don't spend 30 minutes cleaning/regreasing everything. I have not got to test this yet, as the 129 is in rehab for a few other jobs, but it can't be anything but better. This cub's steering was OK as it was so I did not get into the box rebuild. I did pull the foam gasket assy and clean that area as much as I could
Gophred
2 - 1811's with 50C decks, one mows the other is waiting on deck, 129 (my sons retromod)-, hydro lift, custom 3 pt with a trailer ball , foot pedal speed control, used for trailer hauling. 129 (mower) 42" deck, foot control, 1810 with 44C - next in the slow death march of mowing the camp. a few 1200 series parts rigs. 2017 Kubota b2650 loader mid mower.
