Old 12-29-2013, 06:28 PM
tomr80 tomr80 is offline
Default Clutch bearing noise
I believe my clutch bearing is about shot. Here's why I think that, it squeals when it's not engaged. When I turn it on or if it has a belt on it it's fine. I need to know what's the process to replacing the bearing. I can't seem to find an article about a replacement on a 782 or 682. Is there a good/bad bearing to get/or stay away from? Thanks
Old 12-29-2013, 06:56 PM
macman81's Avatar
macman81 macman81 is offline
i have replaced bearings on the quiet line ptos before but most people would probably find a used clutch to be an easier fix.
i believe all thats required it to remove the large bolt in the end of the crankshaft, pull outer half of clutch off, press or drive bearing out(there might be a snap ring behind bearing), and drive in new bearing. if i missed anything anybody please chime in!
John,
PROUD OWNER
Cub Cadet 122, 149, 1650 dual hyd and COZY CAB, 782 dual hyd, 54" power angle blade, qa42a snow thrower, #1 tiller w/extensions, brinly plow,
1940 farmall H, Little Wonder 2 bottom plow, 1954 IH Fridge, 1948 IH 158 chest freezer.
Old 12-30-2013, 03:58 AM
From our Technical section...... Elec PTO bearing repair
