I have long wanted to install a creeper in my 102, so I found a 104 with a creeper. I swapped the 104 creeper, drive shaft, clutch into the 102. When I was done, fired the engine, left the clutch out and nothing..it won't move. It appears as if the clutches are slipping, when in fact both worked well before I swapped everything over. The 102 clutch, drive shaft, works fine in the 104. I did install a new throw out bearing and teaser spring on the creeper shaft. Could the teaser spring not be stiff enough? I split the 102 again and tested the creeper on the ground. It spins over fine when using a drift pin to spin the input shaft. I am lost. Do I need new clutches?
First, welcome to OCC....
![]() As they say, "a picture are worth a thousand words". How about snapping some pictures of your modification so we can see what is going on. ![]()
Did you forget to put a pin in the driveshaft?
Welcome to OCC!
As Roland said get some pictures and post them. ![]() |
![]() Quote:
Welcome to OCC! You came to the right place!
Creeper trouble? Did you try the police??
![]() Hope you get your issue solved.
Daniel G. ![]() . (May 1970) 147 w/an IH spring assist, 48" deck, 42" blade, 1969 73, #2 trailer, 10" Brinly plow and (on loan) Dad's #2 tiller. |
Guys, thanks for the responses, I found the trouble. One pin was waaay to long and actually hit the cross member of the frame, stopping the shaft from spining! Mr Dremel and a tile cutting bit cut the ends off without removing the shaft...I am a lucky dog. I will post pics later...got to get creepn!...LOL.
ok, whats the easiest way to post pics?
down load this program and resize your pics to 640x480. This is a very nice way to play with pictures.
http://www.irfanview.com/
1977 1650 with cast iron lower grill housing, cast iron oil pan, 54" push-snow blade, rear blade, disc-harrow, 44c and 48" decks, Two cultivators, #1 tiller with both extensions, loaded tires, 75' weights and chains, #2 cart. |
