Old 12-15-2013, 06:01 PM
EarlJ's Avatar
EarlJ EarlJ is offline
Default Busy busy day...
Was it ever...rebuilt the carbs on both the 125 and 104...seems like twice the new kits came with the wrong size jets and I didn't realize it until after I reinstalled and started working the tractors... Both stated blowing heavy black smoke and gas was pouring out the throats... Had to pull them both back off and put the old jets back in.. Once that was worked out, I mounted the plow blade on the 125...found out quick there is a fine reason for the holes in the front of the mount...that blade will fall out if they are not in there
126 in surgery with weights, spring assist, 3 point and sleeve hitch
100 with woods finish mower and rear lift,
Nice 125 with super nice sweepster, 1782 Super Diesel,
1650,782D in surgery, 102 parts tractor..
3 Brinley plows, Brinley cultivators , rear scrape blade, front plows and custom built bedder attachment.
Old 12-15-2013, 06:21 PM
Mountain Heritage's Avatar
Tell us more about the wrong parts you got? How did you discover they were wrong, can you notice the difference by looking at them or are they that small of a tollerance the naked eye can't see it? When you say its spitting out the throat - where exactly? You might be onto something for an issue I have with my 100 with a K241 spitting gas out the bottom hole of the carb on the breather side when I choke it???
Mike
Ontario, Canada
Now everyone wants a Cub!
Beware of the Wife
Old 12-15-2013, 06:34 PM
Holes on the front of the mount? Not sure what you are talking about here...
Old 12-15-2013, 06:39 PM
EarlJ's Avatar
At first glance the jets look like they are correct.. The new ones are square where the old ones are triangular.. the square ones don't seem to block the hole when the bowl is full of gas allowing the gas to just run out unabated behind the breather cover.. this was a lot of gas...it's all square with the original jet. The kits are some aftermarket universals I had a buddy get for me.. I'm not sure who makes them though..
Old 12-15-2013, 06:40 PM
EarlJ's Avatar
On the subframe where it turns up on the frame just ahead of the Frankenstein bolts...
Old 12-15-2013, 07:26 PM
cubs-n-bxrs's Avatar
I am not understanding this jet issue. Are you taking about the fuel shut off valves. Any ones I have ever changed come with a viton tip and they are matched to the seat that threads into the base of the carb. Changing them in a pair you should have no issue unless the float needs to be reset with the new parts installed. With the carb held upside down the float should be parallel with the base. If it's not that might be the fuel not shutting off issue.
Old 12-15-2013, 09:17 PM
The cubs are looking good, Earl.
Old 12-15-2013, 09:49 PM
Ah, I understand now. I've got the pins running into the quick release then bolted it to the frame in the holes above for an added security measure. (on my snow blade.)
Old 12-16-2013, 10:39 PM
EarlJ's Avatar
The floats were/are correct.. perhaps I am calling the shutoffs jets the new ones were loose in the journals and would wobble back and forth allowing the rubber needle to stand open in turn allowing fuel to just run through the carb. The fix was to put the old ones in and no more gas issue..
