Old 12-06-2013, 11:17 AM
dbuck dbuck is offline
Default Torque value:
The rear cover gasket is leaking on my 149. I have a new gasket and 8 qts of hytran. In checking the service manual did not see any torque value to use on the bolts when buttoning everything back up, is there one? If so what pattern would you use ? Thank you for your time.
Old 12-06-2013, 12:52 PM
johncub7172's Avatar
Thumbs up
Identify the bolts you are using, there is a chart in the beginning of the service manual that will describe the carbon steel bolts, and give torque values.
Old 12-06-2013, 01:04 PM
cubs-n-bxrs's Avatar
They should be 3/8ths 16 bolts grade 5 with a 33 ft/lbs torque.
Old 12-06-2013, 02:44 PM
sawdustdad's Avatar
I know some folks don't like this approach, while others do the same as me, but I've resorted to applying a very thin coating of gasket sealant (RTV or similar) to both sides of the gasket to ensure a good seal. I was getting leaks about 50% of the time without using a sealant, and none when using it. Just be judicious in the application to avoid squeeze out, especially into the gear case interior. And I let it set up overnight before operating the tractor. Just my thoughts, YMMV.
Old 12-06-2013, 04:12 PM
I do the same thing with the same results....
Old 12-06-2013, 05:04 PM
clint clint is offline
I also use a small amount of grey (gray?) RTV sealant, for the amount of time spent cleaning everything up, and money on fluid it's a no brainer for me to use sealant to insure no leaks.
1440
1282
1604 cast rear/transmission (582)
149
1450 (2)
JD317 54" blade
JD318
Ford 3600
Old 12-06-2013, 05:17 PM
Same here but I let it sit for a day before I fill it with the rear with fluid. Permatex Ultra Grey is my go to silicone.
Old 12-06-2013, 05:46 PM
gmbadgley gmbadgley is offline
Most manufacturers don't even use gaskets for rears anymore, just RTV.
"If I can't fix it, I can screw it up so bad no one else can either"
Old 12-06-2013, 07:00 PM
That's what I do. On any rear end gasket.
Old 12-06-2013, 07:21 PM
We use a lot of anaerobic flange sealant at work. Loctite makes it and its red. Doesn't set up until there is no oxygen and then it hardens fast and seals like crazy. Although I would be cautious using a lot of this or rtv products on rear gasket because if it squishes out and gets into fluid it will clog up hydro stuff and filter I'm sure. And I'm thinking to use some pipe thread sealant on the fill plugs because that's where mine seem to seep a lot. Just my .02
