The shear pin broke and when I took the hub assembly off there were two semi-circular cut-outs where the dowel presses against the grooves in the hub. Are those cut outs supposed to be there or were they worn into the grooves by the old pin?
![]() Quote:
Still don't know what I'm doing in OHIO?.....If you find me, then please point me back toward INDIANA. ![]() |
Those grooves are not supposed to be there. The pin hammers against the sides of the slots and causes the grooves. They can be welded up to repair the hub but will return over time. Some guys choose to replace the driveshaft with the Quietline style shaft with the flex joints on both ends.
Adam 1964 Model 100 w/ K301 12hp and custom hydraulics 1972 Model 149 turned 129 w/ K301 12hp, triple hydraulics, 66 series clone |
Makes sense, thanks
![]() Quote:
