Old 11-28-2013, 04:46 PM
dodger9714 dodger9714 is offline
Default Drive shaft removal
have everything unhooked but i cant get the pieace to the tranmission off, how does this come off??
Old 11-28-2013, 05:18 PM
Rdrnek Rdrnek is offline
there are two 1/4" roll pins that go through that coupler thats at the end of the driveshaft you have to get a punch and pound them out.. with that said its a pain on a narrow frame. thats why you see so many narrow frames with a hole cut in the tunnel cover
-Bob-
149 w/48"deck, 2 100s and and 2 ugly "O"s parts 104
Old 11-28-2013, 05:49 PM
alright thanks, guess ill have to put it up on the lift at the garage and to do it while standing because it looks like a pain laying down.
Old 11-28-2013, 07:43 PM
dgrapes59 dgrapes59 is offline
A 1/4" Roll Pin Punch will make it much easier, they are designed to remove the spiral pins.
This one is long enough to fit through the creeper slot to remove it from the top:
http://www.ebay.com/itm/PROTO-J49014...item338256583e
A set in your box would be a good thing to have. (the above one is about an inch longer than the 1/4" one in the below set, gives you a little more room to hold and hit!)
http://www.sears.com/craftsman-6-pc-...1&blockType=G1
Good luck,
David
David
