Old 11-17-2013, 10:50 PM
SS5150's Avatar
SS5150 SS5150 is offline
Default 782 Carb trouble
Hello again all I've been slowly fixing my 782 up, last night I went out and pulled the air cleaner off only to see raw gas puddled down the throat of the carb (it sat for a week). I've been shutting the fuel off under the tank (although I'm not entirely sure that valve works either). Anyway it is a Walbro carb...which after reading on here isn't the preferred carb.
I have another carb from my Uncle's old 782 that threw a rod.....so I went and pulled it off today, thinking I'd rebuild it and use it.....it is a Kohler carb- only to find out that when the engine grenaded itself shrapnel hit the carb bowl and dented it.
My question is, does Cub offer a replacement bowl? I looked on partstree.com, under 782 carb section, I see part# KH-235448- is this a bowl for a Kohler or a Walbro? I'd hate to order it to be wrong. With the Walbro & Kohler I have here they don't appear interchangeable.
Thanks for the help.
RUN IN THE RED
782 w/50c deck (red); 782 dual stick, 44c deck (y/w);
1050 w/38c deck; 1864 w/54" GT deck;
1872 project
Cub Cadet Pro Z 560 L
42" power angle snowblade, #2 tiller, 2-QA42a snowthrowers, 450 thrower, #2 cart; 54" Haban blade; Brinly box blade, 48" dethatcher, moldboard plow; Agri-Fab sweeper
1200, 1863, 1864 parts machines
Old 11-17-2013, 11:52 PM
Nightow1 Nightow1 is offline
Pm me I think might have one for just the shipping.
Anthyinv to keep a 782 going.
Old 11-24-2013, 01:15 PM
SS5150's Avatar
Thanks to Nightow1 for sending me a carb bowl, got the carb back together last evening.....hopefully I can fire it up again later today.
RUN IN THE RED
1872 project
Old 11-24-2013, 02:27 PM
IF.....you are interested, Kirk Engines ( Kirk ) sells Steel Carb Bowls instead of the OEM aluminum ones. Go to the link and scroll to the bottom of the page.
Old 11-24-2013, 05:43 PM
That's great! Good luck on firing the 782 up!
