Old 11-17-2013, 03:22 PM
Willie Schmidt Willie Schmidt is offline
Default 1250 Air Filter Numbers
I'm hoping someone can help me find the correct air filter for a cub 1250. I ordered one online and it didn't fit. The one that came was unmarked, but measured 4 1/2" I.D. and 6 1/8" O.D. I needed one that measured ID 5 1/2" and OD 7". I returned it for the other option. Now the problem is that the larger diameter filter is 2 1/2" tall and needs to be about 2" tall to fit. The guy selling me the filter is telling me there are only two options, but neither works for me. I'm wondering if he knows what he's selling, or is my machine an oddball or maybe the air cleaner is not original. As far as I can tell, everything seems original.
Old 11-17-2013, 03:32 PM
OldAndInTheWay's Avatar
I got some for my QL at tractor supply. Fit OK.
Old 11-17-2013, 03:37 PM
Do you know the dimensions of the filter you bought? That would be helpful to me.
Old 11-17-2013, 04:14 PM
Willie,
Sounds like they gave you an air filter for a NF and WF cub.
The quietlines take the bigger air filter which is 5-1/2" ID and 7" OD and about 1-5/8" thick.
The Kohler# is KH-47-083-01.
Old 11-17-2013, 04:46 PM
Thanks. The 1 5/8 number is the part they can't seem to get right. I just went out to measure mine. The second one he sent me is 2 1/2" tall. Thanks.
Old 11-17-2013, 05:14 PM
IF you have the original & correct engine for your 1250, then the Air Filter is clearly indicated in the Parts Manual.....being KH-47-083-01
Old 11-17-2013, 09:21 PM
bocephus1991's Avatar
Napa Gold #2296 I tried one from TSC and it didn't fit. It may have fit a wheelhorse or something,but not a cub.
Brian
Old 11-17-2013, 09:50 PM
Since I haven't owned the tractor since new, I can only assume the motor is correct. With the dimensions CubCrazy gave me, I think it's verified. Thanks again.
Old 11-17-2013, 11:54 PM
bkw3614 bkw3614 is offline
I bought an air filter from NAPA for my 1250 Nightmare. It was the exact size of the old one, and I know it is working because of the dust build-up around the outside of the filter cover. Sorry, I don't know the part number offhand. My local NAPA store stocks them.
