Old 01-21-2010, 07:04 PM
Stitch's Avatar
Stitch Stitch is offline
Default Wide frame vs narrow frame -wheel base?
can anyone fill me in on how much wider the axle/rear wheel base on a 149 would be then on my 100? Thanks in advance.
Killin deers and drinkin beers
Old 01-21-2010, 08:26 PM
CubQuest CubQuest is offline
The rear on the 149 is not any wider. The WF vs NF difference is in the frame rails where the engine sets.
Old 01-21-2010, 08:41 PM
I've never actually had a tape measure on either of them, but I don't think there is any difference in the width of the transaxles, the overall width difference comes from the rear wheel width/offset.
For the front axles, the Narrow Frame front axle and spindles are a lot narrower than the Wide Frame front axle and spindles, if the correct wide front wheels are installed on each, the overall width ends up being almost the same, because the wheel offsets are reversed between the two.
Not sure if any of this answers your question or not.
Old 01-21-2010, 10:01 PM
To add....the only thing that comes to my mind is the tire width of the rear wheels. 10.50's vs 8.50's. The rear end and axles would all be the same.
