Old 11-13-2013, 09:16 PM
Green stripe wide frame's Avatar
Green stripe wide frame Green stripe wide frame is offline
Default 125 engine
i just picked up an engine today for my 125 but its a 14 horse will this fit in my 125
Old 11-13-2013, 09:18 PM
Pics would help a lot. Same style starter? Out of another Cub Cadet? Is the oil pan bolt pattern the same?
Old 11-13-2013, 09:19 PM
bocephus1991's Avatar
What is the 14 out of? is it a k321 from another cub?
Brian
Old 11-13-2013, 09:20 PM
MinnesotaCadet's Avatar
You might have to cut the frame like IH had to do with the 147
Connor
Old 11-13-2013, 09:28 PM
it is out of a cub, it does not have a tag on it but is casted k321. really don't want to cut the frame that is why i asked the question. the thing that baffles me is that it has a plastic grass screen on the flywheel, i thought they were all steel
Old 11-13-2013, 09:33 PM
The only thing that I can think is that it might be a newer one? Does it have a gen/starter or and electric start.
Connor
Old 11-13-2013, 09:34 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
You would have to spread the frame like a 147 or take it apart and change the bearing plate, flywheel and tin. Either way, it's allot of work. It's not a drop in.
Old 11-13-2013, 09:36 PM
cadzag72 cadzag72 is offline
the 14 horse k321 has a bigger flywheel than the 12 horse, and it's too wide to fit in the 125 frame without making adjustments (cutouts.) the 10 horse k241 would fit as a replacement along with a the K301 12 horse.
Ian
Old 11-13-2013, 10:10 PM
it does have the start gen bracket on it. i wish it would drop right in. would any body want to trade for a k301?
Old 11-14-2013, 10:26 AM
Vin122's Avatar
Vin122 Vin122 is offline
Where in Wisconsin Are you. I might have a K301 to trade.
