I got one with 2 bad wheels for free from work. New wheels will be $12. From Harbor freight. I plan to build a larger Wooden box on top of it (30*48*16) and see how it does. Its rated at 700 lbs and has the handle that converts to a tractor hitch. I'll take pics along the way.
This is what I'm starting with. ![]()
Cub 104 Refurbed Sprinig of 2013 Aftermarket headlights, 3 point, Brinly Adapter, Spring Assist, 42" IH Blade, 42" Mower Deck, 42" Craftsman Grader Blade, 10" Brinly Plow, 6-12 ags and 22x9.50 turfs |
Your pic just reminded me I have a yellow cart like this or wagon that tilts, dumps, it holds water, etc. Hmm...
![]() Prior to this I use and abused it on a regular basis, and it never failed us. |
![]() Quote:
I added on solid sides to mine to haul dirt if I want. Used it last to spread pete moss on the new grass seed. Rubbed the moss thru to bottom to break it up, rolled around to different areas as I went to spread the moss. Hauls wood a few heavy items from time to time as well.
Need to add. Side to side strength is a concern. Works well when load is centered. Flex in the frame with side load on the front causes trouble. |
Ha i used it to pull wood around with and it was the 1000 lbs rated one already had to reweld the front and rear axles and replace bearings basicly i haave mothballed it in an outdoor building and bought a real trailer and cut it down to a 3 1/2 wide by 5 ft long.. for free though beef it up and buy better wheel bearings when they come out!!!
1782 smoker!!, 169 and parts 128 And a bunch of stuff that fits on the back of them LOL |
