Old 10-27-2013, 07:54 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Smile 1450 time
For the last couple of months I have wanted to get my tiller mounted on the 1450. I finally got time today to do some cleaning of my shop so i thought what the hay?! Nightow1 came up and put a new coil and condenser on it then pulled the carb to do a clean/rebuild. Hoping that this & a few other things might make it run a little better before I go to tilling. I took my cat. 0 off and put the gear box & Cub Cadet 3pt. on. Hope to get some 10.5's sumtime in the near future to replace the narrow 8.5's on it presently. Some time ago I purchased extensions for my 1A from Outsiderline2 that I will get to install . I will post pix of that project aswell as some action pix at a later date. But for now here are a few to look at.
1- 1200 in pieces
1- 1864 in pieces
Old 10-27-2013, 10:13 PM
Glad you got some time with the 1450! Thanks for the pics.
Old 10-27-2013, 10:31 PM
Nightow1 Nightow1 is offline
Lol there that Drill bit box is. I left it on the seat. and the cat 0 3Pt parts are on the floor. My mind don't work like it use to.
Old 10-28-2013, 06:28 AM
Thanks for the pics, looks good!
Old 10-28-2013, 10:43 PM
Rescue11's Avatar
Nightow1 came over and got the cub up and running. He also pulled and cleaned my fuel tank... it had floaties n it. We got it put back together and pinned the tiller on. Apparently my motor shook enough that one of the engine mount bolts fell out. Put a bolt in and it helped some. Makes it hard to adjust the low idle with it shaking so bad right keith? Lol Looks like after tilling season is over it's time for new mounts! No belts or extensions yet. But we will get it there. Cant post pix from phone but will have some n a.m.
1- 1200 in pieces
1- 1864 in pieces
Old 10-29-2013, 04:13 PM
Rescue11's Avatar
should i put the one wheel weight on or take the other one off??
1- 1200 in pieces
1- 1864 in pieces
Old 10-29-2013, 04:18 PM
Rescue11's Avatar
Default Stuck!
Its amazing what a 2wd cub will go through... but they do meet their matches! Glad for the 4wd Farmall
1- 1200 in pieces
1- 1864 in pieces
Old 10-29-2013, 05:14 PM
Not even going to ask!!
Old 10-29-2013, 05:49 PM
I see no farmall....
Old 10-29-2013, 06:03 PM
The big red tractor????
