Old 10-27-2013, 05:38 PM
OldAndInTheWay's Avatar
Default Just an observation..
Mowed leaves and grass with my 124 today (besides beating my head over a Quiet Line) .
Boy, they are nice machines. The 124s.
Having worked on both the early Cubs and the later QLs I can say I love the simplicity of the early ones. The QL I have been working on has been a nightmare when it comes to the electrics. Sometimes it would crank and others not, sometimes the lights would work, sometimes not...
PO had bypassed the safety switch with a nest of mixed colored wires, First the fuse holder was dodgy, fixed that(I thought). The wire at first would read 12 volts going in and out..so I checked the amp meter, ok, got 12 volts. Got 12 to the light switch but nothing out. Took the switch out and cleaned it and got it working, but still no lights? Found out that the 12 volts showing didn't have the current to power the lights. ??????????? Traced it back to the fuse. Cleaned and redid the wiring there... Wallah, fixed the problem.. Oh did I mention the volt gauge was bad as was the hour meter? Finally got the electrical system strait... when it come to the lights.. But starting was dodgy, sometimes it would crank and sometimes it would not... Long story short on that.. replaced the solenoid, still no go? Replaced with one I knew worked..
All this in an area the size of a shoe box.
Oh, and the hydro with it's valves and trunnion and fan...
Will finish it tomorrow... and be done with that one.
Then I look at my Original and 124s and think how simple they are.
Old 10-27-2013, 05:47 PM
PS...
All the electrical problems started after I got the steering wheel off.. another problem, and redid the dash and steering looseness. I guess I stirred up the rust and the problems showed themselves when I put it back together..
Old 10-27-2013, 06:11 PM
Never had/worked on a QL, but this is why I love my N/F. Everything is right there; nothing complicated about it.
Old 10-27-2013, 06:16 PM
NFs are the best
Old 10-27-2013, 07:00 PM
Once one masters a QL, anything on a NF will be a piece of cake. Yep, I will agree.
The NFs are few and far between around these parts.
Old 10-27-2013, 07:52 PM
I am not so sure of the simplicity of the NF,I have the boo boos to prove it.
Try changing a hydro fan,oil filter,flex disc,and even a simple addition of a 3 point can try the best in us,but I will take a NF over a QL any day.
Just my 2 pieces of Bazooka bubble gum in 1960
Up to 534 and counting...
Old 10-27-2013, 07:57 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Never worked on a NF but wouldnt give up my QL !!
1- 1200 in pieces
1- 1864 in pieces
Old 10-27-2013, 08:00 PM
The only one I keep is the 800 in the barn...
Old 10-27-2013, 08:27 PM
Dad's got a 782 and I've never been impressed with the crazy amounts of tin on it.
Old 10-27-2013, 08:33 PM
jonjunk's Avatar
jonjunk jonjunk is offline
Never owned a QL but it's next on the list I like them but wouldn't trade my 122 for one!
122 PTO, lift, deck, weights, and chains clist pick
123 headlights no motor came with the 122
Stx38 free acquisition but its the wrong color works great though
Free craftsman gt 17hp Briggs Intek hydro
