Old 10-26-2013, 09:57 AM
CadetTY's Avatar
CadetTY CadetTY is offline
Default Rear PTO
Looking for info on the parts i need to make a rear pto option on one of my 3speed cubs. How does it work, or go together? If its live that means it always spinning? I have the rearcover and the pto shaft anything else i need?
882 diesel, x3 ih 582, 73 124, x2 82 seriers pullers, 1686 16hp puller
Old 10-26-2013, 10:15 AM
jonjunk's Avatar
jonjunk jonjunk is offline
It is not a live pto which means when turned on it will stop spinning when the clutch is pressed so it will work when in neutral with clutch released or when moving in gear.
Not sure on parts for conversion. Probly best to get a pro rear and swap it.
122 PTO, lift, deck, weights, and chains clist pick
123 headlights no motor came with the 122
Stx38 free acquisition but its the wrong color works great though
Free craftsman gt 17hp Briggs Intek hydro
Old 10-26-2013, 10:41 AM
JLM78 JLM78 is offline
A pic off the webb
Pfunk Pfunk is offline
Unfortunately, you're missing the most important, hard to find, expensive piece. The top shaft in the transmission with a rear pto is different than a standard top shaft. It has a hollow, splined extension on the rear that drives the PTO. You also need the shifting mechanism. To install requires removing the current top shaft and installing the correct one. It takes a while. It's probably quicker and easier to find and install a rear end which already has a pto installed.
A Cub Cadet has a "non-live" Pto. As stated above, the pto on a Cub Cadet stops rotating any time the clutch pedal is pressed. On a "live" pto, there's a two stage clutch. Half way down disengages the ground speed and all the way down disengages the pto. An "independent" pto is operated completely independant of the tractor clutch.
Hope this helps.
The picture was posted while I was typing. Good job. The middle shaft in the picture is the one you need that it sounds like you don't have.
Old 10-26-2013, 10:52 AM
Guys, there is some confusion here. A LIVE PTO is one that is coupled to the motor. Period. No matter what the clutch is set up as. A NON-LIVE PTO was ground driven off a wheel of the tractor. An INDEPENDENT LIVE PTO is one that can be run independent of the transmission, as in a two-stage clutch, or hydraulically operated like IH used on the their tractors.
Old 10-26-2013, 11:23 AM
The rear PTO, IMHO, is worthless. There was NEVER an implement or a attchments made by Cub Cadet that could be operated by it. As stated above, it was a "non-live" feature.
If you are determined to install this on your Cub because of "cool factor".....then this will help.... Install Man
Old 10-26-2013, 11:34 AM
CadetTY's Avatar
Yes just going for the cool factor, iv never seen one in a cub cadet garden tractor besides pictures. I was going to buy the grearbox that runs off the pto. Anyone know if these parts are still available?
Old 10-26-2013, 11:52 AM
I never post this pic,
Good for making ice cream.
Old 10-26-2013, 11:55 AM
jonjunk's Avatar
If the tractor had a creeper would that slow the pro being it's slowing the driveshaft directly or can a creeper not be put on a PTO rearend?
Old 10-26-2013, 12:42 PM
Since the rear PTO on a Cub Cadet is transmission driven, the creeper will slow it down.
And, Jonathan, I don't want to start a gear drive vs. hydrostat type discussion here, but I stand by my original description. A search of the web finds a general concensus like here:
http://forums.yesterdaystractors.com...c.php?t=436505
When tractor companies first came out with "live" PTO, the older tractor systems like on a Farmall H were referred to as "dead" pto's. (Yes, I'm that old.) But that description was later replaced with the "non-live" pto which is a much better description. And, yes, since they are driven off the transmission they can be considered as wheel driven. That's why an over riding clutch on the pto is a really good idea. I know of guys that have ended up in ditches or hit trees without one.
