Old 10-25-2013, 11:11 PM
Dave R Dave R is offline
Default Spiral pin
The drift shaft from the engine to the hydro transmission let go at the front end today.
I don't know what was used for a pin from the engine to the shaft. I got this information from a previous post: You're drive line "drive shaft, front and rear shaft bushings and flex discs" might need to be upgraded. Use Spiral pins and not roll pins for retainers in the drive line and other areas that require them.
What size spiral pin should I get, and what about the shaft bushings?? I don't see any bushing, or where one has ever been at the engine end of the shaft.
Need some help here, and thanks.
Dave in SW Missouri
Old 10-25-2013, 11:21 PM
What model tractor?
Old 10-25-2013, 11:48 PM
bocephus1991's Avatar
Like Todd said,need the tractor model number. And we will help you get up and running!
Brian
Old 10-26-2013, 01:42 AM
Default Spiral pin
Sorry about that guys, 149 Cub Cadet. K321 engine.
Guess I thought you were mind readers.
Dave in SW Missouri
Old 10-26-2013, 07:22 AM
IHinIN IHinIN is offline
The front of your driveshaft uses a hardened dowel pin, not a spirol pin. It is 1/4" dia by 1-1/2" long I believe. You don't have bushings. What you read was referring to the Quietline tractors.
Old 10-26-2013, 07:44 AM
cadzag72 cadzag72 is offline
here's what one looks like!
a bad one:
a good one, installed:
I got mine from a local cub dealer, cost $4.
Ian
Old 10-26-2013, 09:26 AM
An itty bitty thing like that would cost $4. Drives me crazy how tiny parts can be so expensive.
Old 10-26-2013, 09:34 AM
Default Dowel pin
Ok guys, thanks for the info on the dowel pin. Next question, the fiber or rubber shock bushing at the rear of the drive shaft at the tranny end shakes pretty bad. It doesn't turn straight, has some wobble. Is this a problem?
Dave
Old 10-26-2013, 01:00 PM
Does the 1211 use the hardened dowel or a spiral pin in the front?
Brian
Old 10-26-2013, 06:57 PM
Dave
The end of the driveshaft slides into the hydro pump adapter and both pieces wear over time and cause the driveshaft to wobble. Both pieces can be welded up and remachined to fix the wobble. The rubber flex disc gets deformed and should be replaced when the driveshaft is repaired/replaced.
