Old 10-25-2013, 07:40 PM
KayakDon's Avatar
KayakDon KayakDon is offline
Default 450 to 451 blower conversion
I just picked up a 450 blower along with a 2182 with a 60" deck. The 450 is wrong for this mower (PO didn't use blower) because of the 6" PTO pulley. I already have a 2182 with a 451 and I think it would be better to change the 450 to a 451 instead of changing the new tractor to a 4"PTO pulley. That way everything is interchangeable. I think I could just change 2 gears. Does anyone know what part # I would need, and where to get them. Or, is it just easier to change the pulley and forget having everything match. Belts would be different, and one belt number would be nice too. Thanks, Don
Old 10-26-2013, 02:31 AM
rweaver rweaver is offline
you cant get them any more they are all gone been gone sometime and when you could buy them they were 550. a set not cheap
Old 10-26-2013, 10:39 AM
There has been some discussion about this on here before. I ran the ratio's for a guy one time and actually figured out what size of pulley you would have to go with. There was really no way to make it work effectively. You really would be better off selling the 450 and buying a 451.
Ray is right, unless you can find them used, you can't get gears. If you changed the pulley, you would have to have one made, and it would be so big, I don't think you could get the belt to feed up to it right. The belt wouldn't track in the lower pulleys.
Old 10-26-2013, 05:24 PM
KayakDon's Avatar
I thought the only difference is 451 uses a 6" PTO pulley and the 450 uses a 4" PTO pulley. I will just change the PTO and get the shorter belt. Funny part is.. I have an early 2182 that had the smaller PTO and I bought a 451. I had to change the PTO to the larger PTO. I sold Small PTO !
Old 10-26-2013, 06:47 PM
Yeah, the difference is in the gearboxes on the blowers. The ratio of the internal gears is different to account for the difference in PTO pulley sizes.
