Old 01-18-2010, 06:59 PM
metalrain metalrain is offline
Default my new 682 oil gusher
Gentlemen;
Just picked up a 682 (sight unseen)...was told it was a good runner, no smoke, ready to go to work right away....Good news...it does run good...Bad news....its throwing oil.
Looks like its coming from behind the flywheel, not just alittle, alot. And of course, the flywheel is throwing it everywhere. Its the KT17 series ll
after just a few minutes running, major oil slick. I'm thinking seal, but can a bad seal leak that much in just a few minutes? Also, is it a big job to change this out?
Metalrain
Old 01-18-2010, 07:37 PM
Default oil slick
Easy fix?? yes, but that depends on who is doing it.
It does require engine removal and removing the flywheel and cooling shroud's to get at the seal.
I might question if the crankcase breather is ok. The crankcase is suppose to run under a slight vacuum, and you can get by with a little blow by.
But too much and it can help make a leaking seal, worse.
also check to see if the seal in there, is correct, and the one you buy, if you are doing it, is the correct one.
I found a kt17 type 1, with a seal too large on the inside diameter.
probably was a later model one installed by a P Owner
Old 01-18-2010, 07:47 PM
In addition, check to see if there is any "play" in the shaft, indicating a sloppy bearing.
Look at items 7 & 8 in the attached image....
Old 01-18-2010, 08:38 PM
Thanks guys,
I've overhauled a few k301s and k321s in the past, but never dealt with the two cylinders before. I guess i will pull it out and check it over. Is this a common problem with this engine? I was hoping there was something else back there making the mess. I think i'll just replace all the gaskets and seals while i have it out. Is there any other way to check to make sure this is a series ll? The identification tag is un-readable, but the air cleaner does say "series ll".
Thanks for the help....i'm sure i'll be back for more once i get rolling on this thing.
Metal
Old 01-18-2010, 09:10 PM
aagitch's Avatar
aagitch aagitch is offline
Up front on the right side there might be two allen head bolts that cap off the oil filter option. If it has that, it's definitely a series II. Now if it doesn't, it could still be a series II. Where you add oil, I've always seen the Sereis I with just a plug but the Series II's i've seen have oil caps but even that's not going to guarantee what it is.
Old 01-18-2010, 09:21 PM
What is the Chassis Serial Number for this 682...??
Old 01-18-2010, 10:18 PM
The serial number is
2050593U686789
It does have a black oil cap you unscrew to add oil...i'll have to look for the oil filter option.
Old 01-18-2010, 10:37 PM
That 682 is an IH built tractor and if the motor is original, it would be a Series I.
Old 01-18-2010, 10:50 PM
I checked for the oil filter option....it does look like it has a cover with two allen head bolts (the cover is on the lower right front potion of the engine). The cover is right in front of the dip stick tube. Does that sound right?
Metal
Old 01-18-2010, 11:24 PM
Yep, that's a series II.
Don't be scared because it's a twin...they're just as simple as the singles, there's just two of some things. I've been inside several of them. They're a bit labor-intensive, but not bad.
