Tractor is a 107 1970
2nd question. My forward and reverse lever on the dash moves kinda easy. So when it's moving the lever moves kinda easy also. SO I need to hold it still while holding it and the steering wheel. I looked underneath the tractor and seen a bit of linkage but not sure what needs replaced and or tightend up. I assume the lever should move to easy. Here is a video http://youtu.be/HtYJNIBkGa0 |
That is a Mule Drive Extension Spring
Get it from your local Cub dealer or contact our sponsors up at the top of the page, or place a want add here on the site. Part Number: IH-489607-R4 Price $6.44
DWayne 1973: 128, ag tires, 3pt. lift, spring assist, lights, 42" Deck 10" moldboard plow 2016 XT1 42" deck 18HP |
Thanks will defy hit them up on that. That takes care if first question
The tension adjustment for the Hydro Handle is in the Service Manual as found in our Technical Library Section.
Thanks very much. Please don't feel like
I don't search. Just bit harder on a phone. Plus I have no idea what the smaller parts are called. This is my first tractor ![]() |
The service manual def. will help. There is a nut inside the dash that needs to be tightened to make the hydro lever not flop like it is. Good luck.
Daniel G. ![]() . (May 1970) 147 w/an IH spring assist, 48" deck, 42" blade, 1969 73, #2 trailer, 10" Brinly plow and (on loan) Dad's #2 tiller. |
An open end wrench, 1 1/16, cut to about 3 inches, will help you tighten the lever tension nut.
Ok I found this hidden adjustment nut lol.
Need to get to it now |
Ok trying to remove the steering wheel, and the speed control lever.
I have the nut of the wheel abut wont budge. The lever I have the screw backed all the way out but wont budge, |
