Old 09-15-2013, 08:49 PM
ddsmith60 ddsmith60 is offline
Default Cub Cadet Drive System Fluid Plus 739-3121
I went to the Cub Cadet dealer and they said that this is the fluid I need for my 1450 hydro oil. I don't see the HY-TRAN I was expecting to see, so I passed on it until I got some feedback from you guys. I have gone through a bunch of post and and I would be good if there was some mention on it that referenced HY-TRAN. The salesman also stated something that I have heard from another supplier about this being 20W-50 synthetic oil. Does anyone here have some details. I don't mind spending the money as long as it is the right stuff. Thanks in advance.
Don
Old 09-15-2013, 09:12 PM
This is what is recommended for your 1450....... Hydro Fluids
Old 09-15-2013, 10:06 PM
jimbob200521's Avatar
Or if all you have is a New Holland dealer local (like I do), Master-tran is the exact same thing as Hy-tran but with a New Holland label.
As far as other fluids aside from what was recommended above go, just pick a good quality fluid. You don't HAVE to have hy-tran/master-tran but in the long run, you get what you pay for. Biggest different is it can absorb liquid, saving potential wear and tare on your transmission.
I used a different type of fluid in my gear 1050 and it works just fine but next fluid change, I want to go back to master-tran just for peace of mind. Other people have had good luck with Tractor Supply brand fluid. It's not like putting a different fluid in your machine will make it go boom, just use good judgement and you should be fine
-Ryan
