I was wondering if someone could tell me how to measure the paint/reducer/hardener in a paint measuring cup? I've watched a few youtube videos but still confused. Im planning to use a 4-1-1 ratio.
Thanks, Nate
Owner of: cub 1650 cub 122 |
If you want a 4:1:1 mixture, you'd fill the level to 4 on each of the 3 scales. The two columns to the right of the first one are exactly 1/4 of the first one.
For example: You fill the cup to the level 7 with paint. You now would fill the second column with reducer to the 7 level. Now add the catalyst to the 7 level in the right column. This is what i used as a guide,if you want the finish harder add alittle more hardner(does not take very much) If you want it more glossy use more reducer(does not take much either) Practice on something like a car hood and get used to it. I had to repaint my fenders because I put some runs in it. Just put thin coats on and build up don't try and put to mush paint on at once. Hope this helps!
Brian April 1979 1200 Quietline 44A deck 1988 1211 customized into a 1288 with a K301AQS 38C deck and a 1864 54” deck . Snow blades 42" and 54" . Brinly disk, brinly plow a cultivator and a $5 brinly yard rake!
My cups have the scale, and just numbers going up the side. If you don't understand the scale, just keep the ratio the same with the numbers. I.E. 4.1.1; 8.2.2; 12.3.3 and so on. BTW, you say your "planning to use 4.1.1" The paint can tells you what ratio to use. Is that the ratio it recommends?
