Anybody know what size bolts Jeff's adpater uses for tightening up the implement to the hitch? I think they are 1/2" but not sure. Also how long should the bolts be?
For that matter I am new to this stuff and know I have seen some discussion on whether or not to use them with a moldboard plow. Any thoughts? What about with a cultivator? Last question, if you don't tighten them up like some have suggested when using a plow do you need to use a "jam" nut or something to hold them in place and keep them from backing out? |
I'm pretty sure that you only use the implement pin when attaching the plow to the sleeve hitch adapter. My understanding is that the plow needs "wiggle" room. I think the pin diameter is 5/8" and it's about 4 1/2" long. I bought one of the kind with the red handle on top so that I can just drop the plow to the ground, pull the pin and it's all set. I'm not sure about a cultivator so others can help in that regard.
