Im picking up a red cub 482 without an engine and was wondering if anybody knew what good bolt in engine replacements were good? Im looking for the best overall recommended engine with the least amount of cutting frame and hood to fit. Thanks
Cub Cadets: 582, 682, mini 5288 and 5488 Case International 235 compact Implements: Brinly cat 0 moldboard plow, Briy cat 0 disk, field cultivator, 1 row cultivator, wheelhorse fertilizer spreader, drop seeder, dump wagon, 44 inch deck, 50" deck, 60" haban deck, front snowblade, brinly cat 0 rear blade, homemade weight bracket, thatcher, harrow, Bush Hog pull type 50" flail mower, Haban 54" snowblade, 6 foot crumbler, straight shank Living a dream one row at a time |
The 482 came with a single cylinder Briggs , it didn't bolt directly to the plate , it used "risers" that the Briggs bolted to.
The single cylinder Kohler also used the "risers" , ala 1282 and whatever other Cubs used the single cylinder. The 1050 Cub used a differnt mount setup for its Kohler. Kt's , Magnums , and Commands will bolt in and you may be able to use the mounting plate you have , it should have differnt placed holes in it for different engines. Although these engines used spacers to raise the engine , and there will be easy wiring and driveshaft mods. Pics are straight from Partstree , a good resource for info... Top three pics are , 482 Briggs , 1282 K , 1050 K , bottom is 1811 Mag. |
Thanks guys, I appreciate the info.
