Old 04-01-2009, 02:26 PM
Mike_s_82 Mike_s_82 is offline
Default Model 148
I am picking up a 148 this week. I have not been able to find any info specific to this model. It us hydrstatic with an electric lift. Any help would be appretiated. Thanks.
Old 04-01-2009, 02:50 PM
MBounds's Avatar
MBounds MBounds is offline
Hi Mike S 82:
1) IH did not make Cub Cadet gear shift of any series with 14 hp single cylinder Kohler engine.
2) An even number last digit with the "8" indicates a gear shift tractor of the 1x8/9 series.
3) A hydrostatic transmission will have an odd number digit in the last position.
4) A 14 HP Cub Cadet, with a Hydrostatic Transmission, of the 1x8/9 series will be a 149.
5) The serial number, found on a riveted tag at the left rear of the differential housing, will help you (us) determine the specifics of your tractor.
Myron B
Old 04-01-2009, 03:02 PM
Default 148
Well I have seen that suggestion other places, and I have also seen other people say they have 148's. My father has 2 of them, and I will be getting at least one of them this week. I will get pics and sn's and any other info I might need off of both of them. I know one has a newer K321 engine, but have not looked at the other.
Maybe we need to find out who is selling the 148 stickers and have a little talk with them. Just kidding, I hope to sort it out soon.
Old 04-01-2009, 03:26 PM
ajgross ajgross is offline
Inactive Member
You said it's hydrostatic with a electric lift. That should be a 147 and not a 148. Like Myron said, if it's a hydro then it's either a 147 or a 149. Although, I'm leaning towards a 147. The 149 should have hydraulic deck lift. 147 came with electric lift.
AJ
Old 04-01-2009, 03:55 PM
Mike:
IH Cub Cadet NEVER made a 148.
Like Myron said, the information on the Model & Serial Tag will positively identify it. You could also post pictures of it...
Old 04-02-2009, 10:05 AM
MBounds's Avatar
Mike: As AJ said.. the Hydrostatic 147 is also a possibility. Sometimes folks will install a higher horsepower engine in a Cub Cadet and give it a "Spoof" model number just for "fun & giggles". For instance, if a 14 hp engine had been installed in a 108 chassis, the owner may have then called it "148" and could even have had some decals made for it.....but that does not and will not make it an IH Cub Cadet Model number. Read again what Roland B said. IH Cub Cadet NEVER made a model with that number, no matter what you may have "heard" or read. Just post the data from the riveted tag at the rear left side of the differential and we'll all know what Model it left the factory as.
Myron B
Old 04-02-2009, 05:30 PM
Merk Merk is offline
This is an 86 with a 14 horse power motor in it.
The motor is making more than 14 horse power.
To me it is still an 86.
Old 04-02-2009, 07:26 PM
Cubmonkey's Avatar
Cubmonkey Cubmonkey is offline
yeah it might say 148 because i HAVE seen 148 decals on ebay that someone made. But they never made a 148. If it has electric lift id say its a 147. Wide or Narrow frame?
Old 04-02-2009, 07:37 PM
dyt4000's Avatar
dyt4000 dyt4000 is offline
Maybe this was an April Fools joke...
Co-Founder
You only need two things in life...duct tape and WD-40
If it's stuck and needs loosening, use the WD-40.
If it's loose and it's suppose to be stuck, use the duct tape.
Old 04-02-2009, 07:47 PM
Cubmonkey's Avatar
Could Be???
