Old 08-20-2013, 11:07 AM
gcbailey's Avatar
gcbailey gcbailey is offline
Default 149 gas dripping from carb/air cleaner
Pretty much like the title says... I've noticed since I got the tractor it's got a STRONG gas smell, took the air cleaner cover off and the pre-cleaner is soaked. I watched and after about 2 minutes there's a drip of gas coming out of the carb. Like a leaky faucet... not a steady drip, but enough that it falls out of the air cleaner cover after a few. Ideas? Suggestions?
Gary
Old 08-20-2013, 11:25 AM
sgirdham's Avatar
sgirdham sgirdham is offline
If it were me, i would order a rebuild kit from one of the sponsors and totally go through it with new seals, gaskets and such... and shut off your gas at the float bowl when you arent using the tractor.
1981 IH Built 782- 44" deck
1650 dual stick
71 "121" round fender and replacement k301 carlisle tru powers and v61
Old 08-20-2013, 12:38 PM
Ash_129 Ash_129 is offline
Do as sgirdham says.
Your problem with that tractor is a leaking needle/seat.
(Also, make certain to correctly set your float height during the carburetor rebuild.)
Best of luck.
Cub Cadet 129
48" deck - grass mowing
38" deck - backup deck
42" front blade
Old 08-20-2013, 12:42 PM
The needle valve is not seating properly with the seat.
Check for dirt, bad float, stuck float, bad needle, bad seat or any combination.
Old 08-20-2013, 12:50 PM
X-2
Old 08-20-2013, 01:48 PM
red56turbo's Avatar
Gary,
Sounds like a carb rebuild is in order. I always shut the gas off at the tank as well. Even if the carb doesn't leak. Just a habit I guess.
Josh
Diesel Cub Cadets...........
Old 08-20-2013, 05:08 PM
gcbailey's Avatar
Here's the thing... it doesn't have a fuel shutoff or sediment bowl... I always thought those were standard???
Gary
Old 08-20-2013, 08:49 PM
The shut off is right there under the tank, but the handle is broke off.
No bowl on these, but there is a screen (or should be) on the shut off.
Old 08-20-2013, 10:01 PM
bocephus1991's Avatar
Well along with the carb rebuild I would drain the gas and install a shutoff. Might wanna take the tank off and clean it to.
Brian
Old 08-21-2013, 09:01 AM
gcbailey's Avatar
Hopefully I can get started on it this weekend. I don't mind the gas smell, as the garage has smelled like a mix of hy-tran, diesel, gas for years now! But apparently the wife doesn't like getting the buzz from it! haha.
Gary
