Old 08-17-2013, 11:11 PM
bluesman bluesman is offline
Question K 341 info
Generally speaking, can anyone tell me what are the main sources of oil leaks in the k341? TIA
Dave
Old 08-17-2013, 11:16 PM
bocephus1991's Avatar
Don't have a k341 but my k301 leaks alittle around the crankcase breather. Have an old one to get running it leaks around the pan some and drain plug.
Brian
Old 08-18-2013, 07:59 AM
ronalddipietro ronalddipietro is offline
I have a 107..NO LEAKS...K241A...They just cant have leaks....
Old 08-18-2013, 08:23 AM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
there aren't to many place's to leak on them. a crank seal on each end. oil pan gasket, bearing plate gasket, cam cover, breather, fuel pump block off, head gasket, oil fill tube gasket. Dipstick if the rubber seal is shot
most common. seam to be the breather but you really can't do much to that. PTO seal , oil pan or head gasket
Old 08-18-2013, 08:39 PM
thanks for all the answers. I'm just trying to narrow the leak situation down some before I tear into it.
