Old 08-14-2013, 07:22 PM
V30crewcab V30crewcab is offline
Default ID a 42" blade?
This front blade came with my 128, and it works on there, but I've not seen another one like it, when i look thru the parts manuals, etc. just wondering if anyone can identify it specifically. I can't find any #'s on it, and its not the same as the one thats supposed to fit the 128. hopefully someone knows more about it. I may build a new back subframe and use it on my super.
1782, 1862, 1440(sold), 89 1050, 128, 70, some run some don't!
72 scout
IH 404 tractor
Old 08-14-2013, 09:05 PM
The front blade portion, is the same for either NF or WF, being either 42" or 54".
The subframe is where the difference lies.
Click on this link.............. Blades
Old 08-14-2013, 09:45 PM
Yeah I've just never seen another one with the front frame section like this one. all the others i've run across had the stamped steel 1piece triangle. This one has the front frame out of flatbar like the rest of the frame.
72 scout
IH 404 tractor
Old 08-15-2013, 12:56 AM
The rear part of the sub frame looks like it should, except the tube welded to the left side, but I don't think any of the rest of it is Cub Cadet.
Some of the other guys here may know what it is, or was.
It looks like they did a pretty good job on it though. If it works like it should, does it really matter if it is exactly like it's supposed to be?
I modified the blade that I put on my 123, I don't know what the blade was originally for, but it works like it should and it is my main snow pusher.
Old 08-15-2013, 10:25 AM
That's def. not an IH blade....
Old 10-12-2013, 09:31 PM
Just figured I would update this, I found a wheelhorse blade for sale locally, and it looks exactly like the front part of mine. so someone modified a wheelhorse blade to fit a cub I guess.
72 scout
IH 404 tractor
