Old 08-06-2013, 09:12 PM
Ryder Ryder is offline
Default Engine rebuild
I picked up a 1967 Cub Cadet 122. It is solid and has a 52in deck And it has the pulleys for the roto tiller attachment on the rear end, any way it has a 12hp k-301AS motor and it is knocking bad. I have never rebuilt a motor so I would love some tips!!!!!!
Old 08-06-2013, 10:21 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
buy a manual. check the bore for out of round and taper, check the crank for out of round. do it right and it'll last a long time
Old 08-07-2013, 02:20 AM
You don't say if you are mechanical. Have you ever had any motors apart?
Find someone who has you can have come and help you. If you have never been into a motor, there are a lot of things you can miss because of in-experience.
Get a book, like stated above.
Look up the parts FIRST. That way you know what your getting ready to spend and you don't end up with a motor in pieces that you can't afford to put back together. Also, take into consideration that money. If you have never done this before, are you willing to "bet" that money you will do it right?
Like dvogtvp said, done right it will last YEARS!
Find a machine shop that can bore the block (if necessary) and turn the crank (if necessary). Along with measure the parts, and give advice.
Old 08-07-2013, 07:08 AM
Ryder
I know of a shop in Waterbury if that helps. Guy used to do small engines now mostly race car stuff but he may be able to help.
