Old 08-04-2013, 11:28 AM
mgrimm3 mgrimm3 is offline
Default 73/K161 keeps dying
Hi all - hopefully this doesn't make me sound like too much of an idiot, I just have a tendency to start troubleshooting things that don't need it when something goes wrong.
My 73 had been running decently since I got it in the spring, after a little carb adjusting. The last two times I've tried to run it, though, it's died within about 5 minutes of starting. I can work the choke and throttle to keep it firing for 15-30 seconds, but then it dies out and won't restart. I let it sit for 1-2 weeks in between the two times now that this has happened.
I am most definitely a novice with small engine work, so I'm just wondering what is a good place to start with this. Thanks for any input!
Old 08-04-2013, 05:55 PM
cubby102's Avatar
cubby102 cubby102 is offline
I could be a little bit off here but the last two times that has happened I put a new coil and condensor on it and have ben mowing ever since.
Old 08-04-2013, 06:01 PM
Do you have the screw adjusted way to lean? It sounds like to me that it's not getting enough fuel because you can run it with the choke.
