Old 08-03-2013, 09:41 PM
Kratt's Avatar
Kratt Kratt is offline
Default Transmission Main Shaft Replacement
Anybody done a rear end main shaft replacement? I've got a 126 that wouldn't go into 2nd or 3rd gear. I was hoping it was just a bent shift fork, but when I took the shifter cover off, both forks were fine. After looking a little more I found that the main shaft is twisted and that's what is preventing the gear from sliding on the shaft. I was able to bang it loose so it will now go into second gear fine. But the twist in the shaft won't let it slide forward into 3rd.
Wondering if anyone has replaced that shaft and how much of a pain it is?
Old 08-03-2013, 10:41 PM
rweaver rweaver is offline
to replace that shaft you will have to remove the reduction housing and then take the bolts out that hold the bearing retainer and then use a long punch and tap the main shaft out letting the punch go with the shaft and hold the gears while you get the other shaft back in done this a few times
Old 08-04-2013, 07:44 PM
TommyK's Avatar
TommyK TommyK is offline
Kratt, use the search function on this website, search "transmission rebuild". I posted pics of my gear drive rebuild, that may help you a bit. It's exactly as Ray described. It's not difficult, just time consuming.
Old 08-08-2013, 07:00 PM
Kratt's Avatar
Awesome. Thanks for the information guys. Replacement shaft just arrived today, so hopefully i can get that replaced without too much trouble.
Thanks again.
Old 08-08-2013, 07:11 PM
Kratt's Avatar
Great pics TommyK. Those will help a bunch.
What did you guys use for a punch? I'm thinking a length of pipe?
Also, does the shaft slide out relatively easy or does it take some good whacks to get it going?
Old 08-09-2013, 09:49 AM
TommyK's Avatar
Kratt, i have a thin metal punch, handmade, about 8 inches long that i used. It's a hand me down, i don't know what it was originally intended for. If u have a pipe the correct diameter that will fit in there, that should work. I used a rubber mallet to tap the punch, both shafts i removed came out easily. I have a spare tranny completely dissasembled, if you need any pics of something, let me know.
