Old 07-29-2013, 09:10 AM
ClickClickBoom ClickClickBoom is offline
Default Quietline Hydro leaks
I have a slow hydro leak in the 1650, and would like to pull the rearend and replace all the seals / gaskets.
Looks like there are 2 gaskets, 1 at the pump, and one at the rearend? and 2 seals? I haven't found any reference to changing the seals.
Is this applicable to change the pump gasket:
http://cubfaq.com/corkgasket.html
and are these part no's still correct for the hydro filter?
http://cubfaq.com/HydroFilterX.html
anyone have the part numbers handy for the gaskets/ seals?
1872 W/ Kwik Way loader
1650 W/ Dual Hydraulics, and rear lift
Cadplans Caddigger
qa36a blower, tiller, and snow blade
Gannon Earthcavator
Old 07-29-2013, 11:34 AM
If the cork gasket is leaking, change it only. Gaskets and seals that aren't leaking should be left alone. Most of the time, if it isn't leaking, and you do it "just because"...... you'll be left with leaks you didn't have in the first place.
