Thread Tools
Display Modes
I got a 104 and she runs but not the best. I've cleaned the carb twice and still she wants to pitter patter. I can drive it but it eventually cuts out on me. What are some suggestions you guys have? Thanks and for those of you who read about my 149. I got her running good and haven't tinkered with her since. I am going full restoration on the 149. That project follows this one.
IMHO 98% of all carburetor problems are electrical.
Try cleaning the points and setting the timing.
I've thought carb problems on one tractor ended up being a burnt valve and bad head gasket
1981 cub cadet 682 1975 cub cadet 1100 440 Polaris engine 1966 cub cadet 122 |
If it drives and eventually quits, it sounds more like a fuel restriction. There is (usually) a screen on the inside of the fuel tank's cutoff valve. Unscrew that and remove it. See if it's plugging up. You can check quickly--next time it quits, remove the fuel line at the carb and check for good flow. should be a strong steady stream, not just a trickle.
![]() Quote:
![]() Quote:
149,682,1641,1711 with a 12hp in it 1 8" brinly plow 1 10" brinly plow 451 snow blower,H-48 International snow thrower 42" york rake with fold down grader blade. |
where do i get them? and do you know where i could get a carb rebuild kit? thanks- Matt
Any small engine shop should have what you need. I usually get my stuff at my local Napa. Make sure if you buy a coil to get one with an internal resistor. Napa has small engine catalogs and you should be able to get a carb kit as well.
thanks i will give them a call sometime in the near future
