Old 07-26-2013, 06:58 PM
finz68 finz68 is offline
Default rear axle lub
The manual said (to my understanding) that the trans and the rear axle uses the same 30 weight as the motor- shouldn't the rear end require thicker oil?
Old 07-26-2013, 09:01 PM
jimbob200521's Avatar
Depends on your model. Some say SAE30, most are Hytran. I'm sure someone else will chime in with links but in the Technical section there is a page that tells all on this, what models uses what I mean.
-Ryan
Old 07-26-2013, 09:02 PM
sgirdham's Avatar
sgirdham sgirdham is offline
I have read several discussion threads regarding oil on this site. All answers are different depending on who you ask. Most guys reccomend HyTran, some only use the expensive IH brand HyTran and others buy an off brand from Rural King/TSC/Farm Fleet.
Here is one of the many discussions
http://www.onlycubcadets.net/forum/s...ht=hytran+rear
1981 IH Built 782- 44" deck
1650 dual stick
71 "121" round fender and replacement k301 carlisle tru powers and v61
Old 07-26-2013, 11:51 PM
As a loyal user of HyTran, you get what you pay for.
From what you saw in the thread you posted I think you know the answer to your question
Old 07-27-2013, 07:07 AM
johncub7172's Avatar
Thumbs up
I'm a firm believer in using only Cub Cadet Hy-Tran in my IH Cub Cadet 71, and 72. I also use only Cub Cadet engine oil, and Cub Cadet Gear oil as well. Been accused of being a "loyalist" , which that I am!
Though, many other Only Cub Cadet Members will say they have good results with different oils other than Hy-Tran which is good too!
Old 07-27-2013, 08:20 AM
PaulS's Avatar
PaulS PaulS is offline
I have a 102 that was built in 1965. The manual says to use straight 30 weight motor oil in the tranny. I have used both 30 weight oil and 80/90 gear oil and have had no problems. I would presume that with our winters here in central PA the gear oil would be pretty thick. We just drained the rear the other day in prep to paint the rear and the plan is to put 30 wt oil back in. Of course our experience has only lasted since 1975 when I bought this tractor so it has been a kinda short term test.
Old 07-27-2013, 08:29 AM
Here is what IH or Cub Cadet recommends........... Transmission Lubrication Chart
