Old 07-23-2013, 04:14 PM
Green stripe wide frame's Avatar
Green stripe wide frame Green stripe wide frame is offline
Default K-241 rod help
So im working on making 1 good k241 out of 2. the one i want to use has a good bore and a piston but the rod is broke and from low oil, so i bought a scored short block to remove the rod from i did this then i cleaned up the crank and the rod cap doesnt fit like it should is there any markings on the rods that say if they are undersized or will i need to buy some gauges
Old 07-23-2013, 04:26 PM
samiam44 samiam44 is offline
You can look it up in the manual...
But I believe if it is a kohler rod(not aftermarket) which you can tell by the part number. Undersized rod is a drilled hole in the web.
Mic the crank- can you not use the rod/crank combo out of the short block? Make sure the rod journal is smooth an clean. New it measure 1.500 inches.
Michael
Old 07-23-2013, 08:31 PM
well it turned out it has a drilled hole in the webing like you said thank you for that info no i can stop polishing the other crank. reason for not using the hole crank and rod, i didn.t want to have to buy a complete gasket set and have to pull that rusty clutch of again thank you very much
Old 07-27-2013, 03:02 PM
double check with the service manual!!!
