Old 07-15-2013, 05:02 PM
BIGMOZEKE's Avatar
BIGMOZEKE BIGMOZEKE is offline
Default Wiring Diagram for 2284 Needed
Getting no fire to the engine at all and need to rule out all of the obvious items.
Any help would be appreciated.
Thanks,
Joe
1200 Puller[/U][/B]
1864
2072 with 54 Inch Haban Blade
Old 07-17-2013, 06:14 AM
Diagram sent to the E-mail address listed in your profile.
Old 07-17-2013, 02:06 PM
BIGMOZEKE's Avatar
Got the diagrams, thank you Roland
Joe
1200 Puller[/U][/B]
1864
Old 07-18-2013, 07:53 AM
dsmithjr's Avatar
dsmithjr dsmithjr is offline
Bigmozeke when my 2284 done that the key switch plug was loose. The engine would turn over but no fire. I had to take it apart and clean all the connections. I read that this is a common issue with them.
Don Smith
Old 07-18-2013, 09:35 PM
BIGMOZEKE's Avatar
Hey Don, Will certainly check that out. This tractor does not belong to me. I am only trying to help out a friend. This thing has been sitting for over 2 years.
For right now.......the stupid thing has a bad fuel pump absolutely for sure.
When I bypass the fuel pump and gravity feed it from another fuel tank and line set up.......still no fuel into the carb at all.
In the Kohler manual it states that if you do not ground the other plug when testing one for a spark that it will cause damage. I actually did not test the spark myself as I had never gotten around to finding my little tester, but the owner had told me that he and his uncle had already confirmed that there is no spark the old fashioned way, so I am expecting the worst.
Now this is unbelievable, I saw a bolt sticking out of the front of the tractor at the belt lock tensioner to hold the tensioner locked......THEY HAVE A 98 INCH BELT ON THE PTO DRIVE BELT!!!!!! Should be a 114 inch for the 60 inch deck. So, needless to say that has to be fixed.
Kind of worried about how deep I am getting into this thing...keep thinking no good deed goes unpunished. Hopefully this does not go sideways on me.
Will take plenty of pics after I dig into this thing on Saturday if it does not rain on me. He may be selling this thing after it is fixed as he needs the money, but he also had the idea that this thing is gold plated and should bring 2-3 thousand parted out..........LOL
Joe
1200 Puller[/U][/B]
1864
Old 07-19-2013, 07:40 AM
dsmithjr's Avatar
Those tractors have a fuel cut off solenoid and if you are having electrical issues it will stay closed and no fuel will enter the carb. You can use an aftermarket fuel pump and it will work fine thats what I did on mine. I would thoroughly test the solenoid and the pump first. I know this because I spent about two months getting mine lined out. All my issues traced back to a loose key switch and one bad coil after I had replaced many other parts. I think your friend is WAY over on his value estimate of the tractor parted out or whole.
Don Smith
Old 07-19-2013, 08:00 PM
Got some questions:
If you bypassed the pump, and gravity fed the carb, and it still gets no fuel.... how did you come to the conclusion that the pump is bad? .... You bypassed it and it still doesn't get fuel? Did I miss something? Or mis-understand? .....
I would agree.... but I don't under stand how even a longer bolt would get a belt that is short by 16" to work..... it should have been 8" from the pulley... no matter... the math just bothered me.
"but he also had the idea that this thing is gold plated and should bring 2-3 thousand parted out..........LOL"
No questions here.... but that IS funny! Bad math again maybe?
Old 07-19-2013, 10:25 PM
BIGMOZEKE's Avatar
Hey Jonathan, did not post each detail, but I checked the fuel pump properly by first making sure that there was ample supply coming in unrestricted and then added a fuel line to the output of the pump and into the old coffee can and NADA,,,,,nuthin'.
I know that the belt thing sounds impossible, but I have the pictures to prove it. Just emailed them from my phone will post them up in a few minutes.
Joe
1200 Puller[/U][/B]
1864
Old 07-19-2013, 10:41 PM
BIGMOZEKE's Avatar
Pics of the short belt and the bolt "holder upper"....LOL
Not sure if you can see in this pic but it is absolutely positively a 98inch belt on there...the owner confirmed and told me that it was "a little tough" getting it on there.
Joe
1200 Puller[/U][/B]
1864
Old 07-19-2013, 11:54 PM
Ok! That makes a lot more sense. Sounds like your on the right track!
As far as the belt..... I'm speechless. ...... yeah, that definitely needs fixed
