Old 07-15-2013, 04:58 PM
jcrews's Avatar
jcrews jcrews is offline
Default 782 Starting issue
Hello well the 782 is acting up and I'm a little puzzled. The switch works (I think)
the pto clicked when I turned the key, and the I tried bypassing the brake safety switch and it did nothing. I ran a jumper wire from the battery to the starter and turned the switch and it started instantly and ran fine for 10 minutes and stopped and I tried the switch and it did nothing. I checked the fuses and they were not blown. My question is where else should I check?
Thanks for any help.
I H Pushmower,100,104,124,1450,1650,782,982,154 LoBoy,185 LoBoy,2 Farmall A's , Farmall H, and 8 IH trucks
Old 07-15-2013, 05:17 PM
jcrews's Avatar
I just turned on the PTO to see if the switch was functioning I turned the PTO off to try cranking it.
Old 07-15-2013, 05:44 PM
jcrews's Avatar
I use the one 719999 and under
Old 07-15-2013, 05:58 PM
You did what?? It should have cranked instantly..... Or did you mean the solenoid?
Old 07-15-2013, 06:00 PM
jcrews's Avatar
The starter
Old 07-15-2013, 06:20 PM
jcrews's Avatar
I need to get some sleep before asking questions, I'm so tired I didn't think about the solenoid
Old 07-15-2013, 06:23 PM
So.... you basically jumped the starter? Didn't it crank as soon as the wire touched the starter? ....... Then it ran a bit and died?
Old 07-15-2013, 06:27 PM
jcrews's Avatar
yes that is what it did, I cranked it and it ran 10 minutes and stopped I turned the switch (without the pto on) and it did nothing, maybe it's the solenoid
Old 07-15-2013, 06:33 PM
jbrewer's Avatar
jbrewer jbrewer is offline
Check the usual (grease and grime at the solenoid connection) ... you can also try 12V directly to the solenoid terminal and see if that makes it crank
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 07-15-2013, 07:34 PM
Well, the solenoid didn't make it die..... I'm assuming you have the KT engine, and not an M motor. M will run with no power. KT won't. May just have a bad connection at the key switch. It's very common.
