Old 07-11-2013, 03:56 PM
drhntrrmw's Avatar
drhntrrmw drhntrrmw is offline
Default Carburator body repair???
The carburetor body on my Original is broke where the air cleaner bolts on. see picture. It is a bit hard to see but right where the air cleaner meets the carb, very dark spot broken exposing internal threads.
It doesn't effect the use of the carburetor but doesn't allow for a complete seal between the carburetor and air cleaner.
I'm assuming there is no way to fix this. Any solutions???
_____________________________________________
1968 Cub Cadet 72 w/fenders, headlights, rear grote, hydraulics, creeper, rear weight box, deck and QA-42 snow thrower
Spare NF hydraulics, Brinly harrow, Brinly moldboard plow
Lots of Cub Cadets have come and gone...
Old 07-11-2013, 04:39 PM
jimbob200521's Avatar
A well placed swipe of JB Weld may do the trick, it'd be worth a try. Clean the area as best you can, apply JB Weld, let sit overnight, then smooth it out in the morning. Worth a shot I suppose. But if there's a better answer, someone here will know it
-Ryan
Old 07-11-2013, 09:44 PM
fleetlines's Avatar
fleetlines fleetlines is offline
I was also thinking.
J B Weld should seal it but I don't know about holding it. Is that a home made brace for the air cleaner?
Original, Serial #44578, K161S Serial #659144, 3pt. w/ Spring Assist, Deck, Fenders, Lights
72, Serial #231093, K161S Serial #C281773, 36" deck
149 & Original Yard art
1650, Serial #2050067U559932*, K341 Serial #7133367, 3 pt. hitch
1650, Serial #2050670U601762*, K341 Serial #7584702 SIM cab, 50" deck, tires loaded & weighted
123 FEL and weight box
10" & 12" Brinley Plow, Decks, Roller, Cart, Power angle blade, dozer blade, Snow Thrower, Airator, Tiller
Old 07-11-2013, 10:00 PM
drhntrrmw's Avatar
No, that is the factory brace for an oil bath air cleaner.
Old 07-11-2013, 10:20 PM
Weld it is the best solution....that or replace it. I didn't know that you could weld the carbs until I met a professional welder who is also a tractor puller. he's really good at what he does and told me that his friend blew his engine up and blew the ears off of a very expensive carb. He asked his friend what he was going to do with the carb and he said junk it because it was useless now, so he asked his friend for it. His friend asked him what he wanted it for and he said I'm going to weld the ears back on and use it. Well, his friend said no you're not, I'm going to do that! Long story short (too late) some really good welders can fix it, but I'm not a welder.
Old 07-12-2013, 12:30 AM
I am not a big JB Weld fan, yes I do keep some on hand, just not a big fan...
In your case I believe I would try it, as long as the gasket between the elbow and the carb is good, the JB Weld won't be able to stick to the elbow, I would just pack the void full.
You will probably want to take the screw out and put something on it to keep the JB Weld from sticking to it then put it back before you pack it full.
Old 07-12-2013, 12:47 AM
fleetlines's Avatar
Originally Posted by fleetlines View Post
... Is that a home made brace for the air cleaner?
I've got two O's here with the oil bath but neither have that brace. Could I see a pic of it? I thought that was a lot of weight to be hanging off there. This has it and still broke.
Old 07-12-2013, 03:24 PM
drhntrrmw's Avatar
Here are two photo's from different angles showing the brace.
There is the brace that goes from the top of the oil bath air cleaner to the motor as well as a bracket that comes off the top of the oil bath air cleaner and angle down a bit that holds the choke cable.
Old 07-12-2013, 03:58 PM
bocephus1991's Avatar
Could try some JB weld putty in a round tube,hardens fast so be sure your area is clean and dry and rough it up some if you can so it has something to grab onto. Knocked a hold in a transfer case once,thats what I used to patch it. Worked fine. Worth a try!
Brian
Old 07-12-2013, 08:46 PM
jonjunk's Avatar
jonjunk jonjunk is offline
Would you guys suggest jb weld or regular weld to fix a worn hole for the throttle shaft I know a thrust washer is the way to go but not sure where to buy them
122 PTO, lift, deck, weights, and chains clist pick
123 headlights no motor came with the 122
Stx38 free acquisition but its the wrong color works great though
Free craftsman gt 17hp Briggs Intek hydro
