hey guys, im wondering whats a bigger tractor in general, these JD 830 diesels which are worked and always win the pull, [the non painted one always wins] or my IH 660 diesel, the 660 pics are from google images exept the one in the garage, thats mine
mine has a working TA, and is a long tractor and weights about 9000lbs or more according to specs [bare tractor]without weights, mine has weights and filled tires. the 830 is about 8000lbs or more i cant seem to get a exact answer, but i read the 830 was the 660s competition and the 660 was a bit ahead of its time, the 830 has 76HP. i read mine can reach into the 90s HP if turned up injector pump which mine has , just looking for opinions, my opinion is the 660 is bigger, what do you guys think? mine is ready to go and fully serviced and will be pulling this weekend , also read the injector pump turned up can reach 30 more HP mine is turned up, i think one of the 660s in the picss was auctioned off ,
I have never seen a 660IH in person but I have seen a 830 Deere Diesel up close and them things are monsters for thier day and time.
1641, 1541, 682 with 18hp command engine and hydraulics from a 782. 1872 with a power angle blade. |
i agree, but i believe the 660 is heavier and more horsepower, also longer, but cant guarantee anything
Is the 660 on the same basic frame as the 460 and 560's with just a larger engine? Where abouts in NY do you pull that beast at?
the 660 has the same frame i believe as a 560, same engine,model D282, exept the pump makes it have more HP and its bigger, [muh more heavier] we will pull with the 660 for the first time in our club this weekend on long island
the 660 is much heavier than a 560
the 560 spins up to 1800rpm, the 660 spins up to 2400rpm i think
The 560 and 660 had different rear ends. The 560 had bull pinion final drives, the 660 had planetary finals. 660 was only offered as a "wheatland" style tractor. 560 Diesel, high idle no load, 1965 RPM. 660 Diesel, high idle no load, 2615 RPM.
wow thanks jonathan, so which is bigger 660?
Toss up. VERY comparable tractors. 660 is heavy, and has higher RPM, JD has more cubes, and you can lug the motor to near stall... tough call. I am nothing but a IH tractor man..... but the Deere 830D will give you a run for your money. You gonna pull the 660?
