Old 07-05-2013, 12:33 PM
Default cub cadet 107 wiring HELP
guys, my 107 still only starts when i turn the key on and jump start it, then when i shut the key off it cranks until the battery dies, tried rewiring solenoid, heres some pics, had new wiring too.
Old 07-05-2013, 12:34 PM
maybe the solenoid or key switch is stuck
Old 07-05-2013, 12:35 PM
the safety switch, someone stuck wire in there
Old 07-05-2013, 12:36 PM
here it is
more wires
Old 07-05-2013, 02:23 PM
Have you tried cleaning the connections/terminals?
Old 07-05-2013, 03:25 PM
I think you wired the solenoid wrong. Does it start cranking when turn the key to the start position, then never stops? If so, you probably did. Battery (+) to one big sol post. (Doesn't matter which one.) From the SAME POST to the key. Start position on the key to the SMALL solenoid post. Other BIG solenoid post to the SG. I'm sure Roland has a pic floating around on here somewhere.
The jumper wire on the safety switch won't affect it. That is NOT causing the issue.
Old 07-05-2013, 04:23 PM
ok thanks, i tried wiring it correctly then put it back to the way i had it, im sure i have it right, i just tried a different VR didnt change a thing, didnt really clean the connections, i hope the wiring isnt burned up, i did have the wrong VR on it
Old 07-06-2013, 12:38 AM
cubby102's Avatar
cubby102 cubby102 is offline
Try unplugging the ignition switch when it won't stop cranking. If it does stop there's two things that could be wrong. One being the switch has bridged connections inside and needs replaced or two the coil wire and starter wire got swapped somehow. Good luck with figuring it out
Old 07-06-2013, 06:12 AM
ok thanks
