I just bought a 1864 as a parts tractor. The PTO has a bad bearing. Can the PTO be repaired or am I SOL?
Yep the bearing can be replaced, someone did a thread on this here a while ago you will have to dig around for it unless someone else chimes in.
Bump bump bump bump
1- 1864 Dual hyd, cat 0, axle braces 1- 1450 Dual Stick w/ power steering 1- 1200 in pieces 1- 1864 in pieces QA36A Thrower, #1 Tiller w/ extensions, IH windbreaker, IH wheel weights, 44C mower deck, 50C mower deck, CCC 54" Blade, GT46 high vacuum deck, GT54 deck, Cub Tripple Bagger, Custom dozer blade, Custom suitcase weights, 3pt cultivator, lawn sweeper, original R-Bucket |
