Old 07-01-2013, 08:47 PM
dsmith dsmith is offline
Default 1650 flywheel
I have been lurking on the site for about a month now. I would like to thank everyone involved for this great site.
I have a 1979 1650 with 3 point lift, front hydraulics, 50"deck and blade that I purchased about 2 years ago. I have recently done the craddle mod, installed new points/condenser and plug/wire.
The leading/forward edge of the teeth on my flywheel are worn. It surprisingly sounds fine but I would like to get a spare to keep in the shop just in case.
Does a flywheel from a 1250 and 1450 fit on a 1650?
Old 07-01-2013, 08:58 PM
machinehead323 machinehead323 is offline
are they worn down or the leading edge angled? i thought mine was worn to but it looks like it was manufactured that way to give a lead in for the starter.
1979 1650, #1 tiller with one extension, 90 degree box mounted, 3 point. 1961 4 digit bringing back to life. I have the mower and 3 pint for it. The 1650 is the fastest mower in the neighborhood.
Old 07-01-2013, 09:46 PM
rweaver rweaver is offline
I sell ring gears to a pulling supply house and all the ring gears have a taper to them it helps the starter engage I have only ever seen like 1 or 2 that were not usable send a pic and we can help you make sure yours is bad but yes any mag or k series ring gear starter single cylinder or kt17 m18 m20 ring gear is the same commands are not the same
Old 07-01-2013, 10:16 PM
