Old 07-01-2013, 03:14 PM
Default cub cadet 107 wont start
guys, my 107 wont start, it only starts with a jump, but i tried another solenoid, that still didnt change anything, it cranks ALL BY ITS SELF when i jump start it, the key switch doesnt crank it anymore, any suggestions
Old 07-01-2013, 03:34 PM
Did it crank with the key before you changed the solenoid? If it did, you hooked up the solenoid incorrectly.
Old 07-01-2013, 03:42 PM
no, with the solenoid i put on, it didnt help at all, it cranked when i turned the key not long ago, but when i shut it off one day it wouldnt stop cranking, once i jump it and its running, when i shut the key off it cranks itsself until batterie weakens
Old 07-01-2013, 03:44 PM
More than likely your points for the cutoff relay on the vr are fused together.Remove the pos batt terminal and clean them with a small file or,nail file.
Would you like a manual?
Old 07-01-2013, 03:57 PM
the VR is the wrong one i put on, but it ran off it, but got hot, idk if anything burned
Old 07-01-2013, 04:08 PM
Now why would you do that?
Did you melt any wires?
Get the correct one.
Old 07-01-2013, 04:12 PM
i dont know, it has a new wire harness, i changed the pos batterie cable, old one looked burned, i put a used pos batterie cable on but didnt change any thing, why would i do it u ask? because i rig and im cheap LMAO
Old 07-01-2013, 04:17 PM
Did you see smoke Ke-mo sah-bee ?
http://claytonmoore.tripod.com/lonergtv.wav
Old 07-01-2013, 04:18 PM
what, the vr smoked and gets hot and starter generator
Old 07-01-2013, 04:27 PM
Nick,
get out your volt meter and check all the wiring for continuity.Hopefully you did not melt any wires inside the wire loom.Do this with the battery disconnected.
Do this before you buy a new VR Ke-mo sah-bee
