Old 06-30-2013, 12:14 PM
Hand_108 Hand_108 is offline
Inactive Member
Default Oil Leak Fix.
Well with the 1200 done, I was able to get out today and mow with it. Noticed an oil leak (not huge, but noticable) at the govenor shaft. Is this normal and is it fixable? Is there an o-ring or gasket in there somewhere? Gonna do some research also to find out but didnt know if anyone has had same problem or if its kinda normal.
Thanks all
John
Old 06-30-2013, 04:27 PM
cubs-n-bxrs's Avatar
That is a common area for a small leak. No o-rings it would affect how the governor works. About the only fix is a new brass nut and cross shaft.
