Hello,
I hope you guys can help. Ii have a Cub 102. I just got my hands on a rebuilt 42 in. deck. I got every thing together and the mower stays engaged, when I turn the motor over the mower turns over as well, the engagement lever does nothing. |
Welcome to OCC
If I understand your post correctly, the problem is PTO related. Go to the tech section here and download the service manual for your tractor. It is full of useful information regarding your tractor. Compare your set-up with the exploded view here to make sure all the parts are there and that none are missing. http://www.partstree.com/parts/?lc=c...&dn=0009500015 Adjust your pto release lever so that a good thick business card will slide easily between the wear button and thrust button. When the handle for the pto release is pulled back, the pulley on the pto should turn freely by hand (with the engine not running). These thing may or may not fix your problem, but it gives you a place to start, so in case you need more help you will have a better idea of the pto and it's related parts, and then you can ask the guys here more specific questions to get more detailed answers. Good luck
