Old 06-26-2013, 07:25 PM
mike melillo mike melillo is offline
Default Tire Selection
I'm contemplating the tire style for my 149. I'm considering dedicating this unit to a snow plowing tractor, and the option of going with the Firestone agricultural (AG) tire, or a turf tire with chains. I have never run an Ag tire with chains, or an AG tire on a garden tractor. Chains seems like a bad idea on this tire type, and I'm not sure if they will bite as good as chains on turf tires.
When I run chains on my 125 with turf tires it works pretty well.
What do you think?
Mike
Old 06-26-2013, 07:38 PM
This has been hashed to death. If it is going to be a dedicated snow rig, 1 turfs 2 chains 3 load the tires end of comments.
Old 06-26-2013, 09:12 PM
johncub7172's Avatar
Well, its always fun to spend money on these tractors making then look better and all. I run turf and 4 link, wheel weights, 60#counter weight, me @ 212#, and have never had any problems, and we get snow here in ne ohio!
They have a special chain for ag tires, but also I have seen 4 link fit a ag tire a lot better than the 2 link will. Should I load my tires using tubes, I will use/recomend Rim Guard. Its like 11# a gallon, and freeze resistant to like -35* .
Old 06-26-2013, 09:30 PM
4SPEED's Avatar
4SPEED 4SPEED is offline
Turf or AG's , it doesn't mater. Load the tires and use a good chain. And you get the same result . Ag tires only work well in dirt pulling a tiller, plow, trailer.
Doug
Original , 100 , 125 , 582
Old 06-26-2013, 09:51 PM
But Ag tires just look so cool on a 149
Old 06-26-2013, 09:58 PM
jimbob200521's Avatar
Depends on what you want to do: play in the dirt, ag tires. Mow or do anything where you want to minimize ground damage/disturbance, turf tires. Snow, turf tires with chains and weights or ag tires with weights and with or without chains, both will be about the same with snow it's whatever you have on the machine.
My vote goes for ag tires, though; looks sooooooo much better
-Ryan
Old 06-26-2013, 10:27 PM
jlampe94's Avatar
jlampe94 jlampe94 is offline
IMO Carlisle tru powers are about the best tire you can get for an ag. Great traction year round and they arnt too bad on the turf. Another tire to look into maybe that may do good in dirt, grass and snow are Carlisle field trax or all trails. Plus they have that aggressive look too.
Original,100,123,129,1200,1250,168 in progress (3) 42inch plows, QA-42A,#1 tiller, 10inch brinly plow, Case Ingersoll 224, 1948 Farmall H, 1950 McCormick W-6, 1952 McCormick W-4.
Old 06-26-2013, 11:51 PM
I agree with EVERYTHING Sam Mac said!
Diz, your ags do look great.
Old 06-27-2013, 06:36 AM
I was going to reply with something but sam mac beat me to it. Get another set of wheels and if you want AGS put on ags if you want turfs put on turfs. That's what I plan on doing with my 147.
Old 06-27-2013, 09:37 AM
Some day the GT world will move past the 1960's and into the modern world!
Bias ply tires look traditional, I will keep them on this tractor, the turfs look good, and do everything necessary on grass/dirt.
BUT, when you want to roll snow with a two wheel drive, modern radials really eliminate the need for chains.
NOTE: After my SIL rolled a truck on an icy patch, I do not go out if there is ice. I wait for it to melt, a perk of living in Virginia!
