Old 06-18-2013, 10:34 AM
OhioTractorGuy OhioTractorGuy is offline
Default 129 Throttle Woes
My newer to my 129 runs fine, but the throttle lever "drifts" from what ever setting you have it at to the low speed. Is this a sign of a 42 year old cable needing to be replaced, or can this be adjusted w/o goofing up the ability to adjust the throttle? Thanks for your patience with a rookie here!
Old 06-18-2013, 11:01 AM
Most likely.....
Old 06-18-2013, 02:40 PM
jimbob200521's Avatar
I've not worked on a 129 myself but from just about every throttle I've worked on to date, there is usually a nut/bolt where the throttle lever links up to the throttle cable right below the dash that can work its way loose. I'd check that to make sure it's snug before I replace a cable or anything. Good luck!
Old 06-19-2013, 12:36 AM
I believe jimbob is correct, there should be a bolt and lock nut that holds the lever to the mounting bracket, that can be tightened to provide more resistance,
If I remember correctly you may have to take it out of the dash to tighten it, but I don't think you have to take it loose from the engine.
Old 06-19-2013, 02:59 AM
And if that don't do it, , set the throttle at full throttle position.
Then, put a couple minor (I mean REAL minor) "kinks" or bends in the cable.
Heck, you are gonna replace it anyway. The throttle will want to then stay at full throttle.
On the ones I have done, it worked perfectly.
Remember, minor!! you can probably do it with your hands.
