Old 06-09-2013, 08:57 AM
mike melillo mike melillo is offline
Default Hydraulic lift valve conversion to 4 port
Has anyone seen a conversion to convert a standard 2 port lift valve to a 4 port for the front accessory ports on a wide frame series?
I'm considering the modification, but I would only do it if I could find the parts to do a clean install.
Mike
Old 06-09-2013, 09:27 AM
Jumper Jumper is offline
Mike, I have seen a few used front port complete systems for sale, control levers, hyd. valve, supply lines and front couplers for wide frames on epay. I'm also sure our sponsors can help you with the parts your looking for.
Old 06-09-2013, 11:33 AM
Mike
Are you asking about converting the spool valve? In hydraulics, the amount of ports is not what you go by, but the spools in the valve. Are you saying you want to go from a single spool to a 2 spool valve so you have the front remote outlets?..... Or are you wanting something different?
Old 06-09-2013, 05:53 PM
Yes, two spools for front connection ports.
Old 06-09-2013, 06:49 PM
Ok. Well, this guy did have EVERYTHING. It doesn't show it in the pic. I had asked him about it earlier. He had them listed separate. No one bid, said he would put them all together.... If he actually did. I am no longer interested in it. Might send him an e-mail and ask if what's pictured is it.
http://www.ebay.com/itm/200876530078...84.m1438.l2649
Old 06-09-2013, 07:40 PM
Thank you, I'll check into this
Mike
