Old 06-07-2013, 04:23 PM
fleetlines's Avatar
fleetlines fleetlines is offline
Default Original Reduction Drive Shaft Oil Seal
I need a Reduction Drive Shaft Oil Seal for my Original. That was part 377959-R91 and is NLA. What is a suitable replacement and where would I find it?
Original, Serial #44578, K161S Serial #659144, 3pt. w/ Spring Assist, Deck, Fenders, Lights
72, Serial #231093, K161S Serial #C281773, 36" deck
149 & Original Yard art
1650, Serial #2050067U559932*, K341 Serial #7133367, 3 pt. hitch
1650, Serial #2050670U601762*, K341 Serial #7584702 SIM cab, 50" deck, tires loaded & weighted
123 FEL and weight box
10" & 12" Brinley Plow, Decks, Roller, Cart, Power angle blade, dozer blade, Snow Thrower, Airator, Tiller
Old 06-07-2013, 05:53 PM
cubs-n-bxrs's Avatar
Best I can say is to remove the seal measure the ID,OD and the thickness of the seal and go to Napa or somewhere and see if they can cross reference it. Is that shaft torn up or is it just the way it looks in the pic.
Old 06-07-2013, 06:08 PM
fleetlines's Avatar
The shaft is alright. The seal is bent though.
Old 06-07-2013, 06:20 PM
AALDRICH AALDRICH is offline
Here you go. my NAPA had them in-stock. Not as wide as the original. Mine did seep after I installed it. not bad, but still a little leak. hope this helps. -AL.
Old 06-08-2013, 10:19 AM
fleetlines's Avatar
Thanks guys.
