Old 06-02-2013, 01:14 PM
nutzboutoldies's Avatar
nutzboutoldies nutzboutoldies is offline
Default 1450 Front Wheel.
Do any of know what if any front wheels will interchange with the 1450? Mine is 16X6.50X8. I would think other tractors used the same wheel.
Steve
1450
QA42A Thrower
44A Mower
Old 06-02-2013, 03:48 PM
rweaver rweaver is offline
what size is your spindle 3/4 or 1 in
Old 06-02-2013, 09:36 PM
I believe my spindles are 3/4". I'll verify tomorrow, I bought new bearings for the other wheel and have the old bearings to measure.
Steve
1450
QA42A Thrower
44A Mower
Old 06-03-2013, 01:33 AM
If you have 3/4" spindles then any Wide Frame Or Quiet Line wheel (for 3/4" spindles) is correct.
The same is true for 1'' spindle wheels.
Narrow Frame wheels look the same but the valve stem is on the other side. If you put a Narrow Frame wheel on a Wide Frame tractor (with the offset going the right way) then the valve stem will be on the wrong side and will hit the axle/spindle every time it comes around.
Old 06-03-2013, 01:39 AM
Likewise, I put WF tires on my 73NF and experience rim rub to the axle....might just be my cub though...
