Old 06-01-2013, 11:37 PM
Chuck Sullivan Chuck Sullivan is offline
Question cub cadet 149 issues
Hello,
I am new to site I need help with my Cub 149 hydrostat. While blowing snow this winter, the shaft from engine to charge pump came off flex coupling and cut open the trans filter, along with some other damage. I replaced the shaft, cooling fan, flex coupling, and drive flange. I filled the hydro w/ fluid. Now it acts like the tractor wants to move but doesn't. Any ideas?
Old 06-02-2013, 06:56 AM
First, welcome to OCC..........
I would check the Spirol Pin that secures the Drive Flange to the input shaft of the Hydro.
Old 06-02-2013, 08:05 AM
As the 149 came with a solid coupling, it sounds like your 149 has been updated at some point to a flex coupling!
Anyway, I have seen some hydraulic systems that are hard to bleed after a filter change, especially if the wrong alternative filter is substituted.
So, my question is,
did the correct filter get installed??
Old 06-02-2013, 08:39 AM
Welcome to OCC! Good luck with your 149. They are great tractors.
Old 06-02-2013, 11:49 AM
Mlohss's Avatar
Mlohss Mlohss is offline
149's do have a flex coupling at the back, anda solid drive pin like the rest of the n/f's at the front. Is this your setup?
Old 06-02-2013, 12:10 PM
From the Parts Manual......Check that item #36 that secures item #4 to the Hydro Input Shaft is not broken.
Old 06-02-2013, 01:20 PM
red56turbo's Avatar
Yep,
The 149's came from the factory with the flex coupling or "rag" joints as some call them. Check your relief valves and make sure one of the tabs isn't stuck down.
Josh
Diesel Cub Cadets...........
Old 06-02-2013, 02:38 PM
Yep,
Yup, this is where I'd start, then the spiral pin in the trans input shaft as Roland suggested.
Old 06-02-2013, 09:49 PM
Originally Posted by Chuck Sullivan View Post
Hello,
Old 06-06-2013, 11:11 PM
Hi I replaced the drive flange, spiral roll pin, cooling fan,flex coupling and main shaft. when the old one came appart it damaged the filter as well, so i replaced that and filled rear differential with hy-trans fluid to top of plug hole. this 149 has a hydrulic lift and that works just fine. thanks chuck s
